Shaders
Hi. I'm confuse.
See image...
How I must to use the shaders in: "Shaders presets - Iray - Daz Uber"?
  • nemesis10nemesis10 Posts: 3,905
    jesuschoy said:
    Hi. I'm confuse.
    See image...
    Select your figure/prop/whatever in the scene tab, select the surfaces you want changed in the surface tab, double-click on the prefered shader, light scene and render.  The key thing to remember is that a shader needs to know what surce it should be applied to rather than a material which already contains that info.
