Fiber eyebrows not following brow morphs
Been puzzling this one. I used Teen Princess Leila for G3F eyebrows on G8F. No problem getting brows to autofit and parent. But for some reason, the brows won't follow the pose of the figure brow.
I've checked about everything. I can only think that I must be missing an autofollow parameter somewhere.
Any ideas?
Think you are on the right track, go to the G8F brow morphs in the parameter pane and click on the gearwheel on the upper right corner to open the edit options to check
if autofollow is enabled for those morphs!
Note that if you change any settings you might have to refit the brows to make them recognize the change.
