JeanZ for Genesis (commercial)
2»
  • ForbiddenWhispersForbiddenWhispers Posts: 1,436
    I don't see the belt being an issue. It can be made invisable so that it doesn't render. I even included MAT files so you can make the belt be removed as well as the buckles.
  • Tramp GraphicsTramp Graphics Posts: 2,422
    edited April 2013
    OK, so here's another question applicable to both versions: one of my other girls where's over-the calf cuffed boots (the top's just below the knee). Can either of these Jeans be "tucked into" the boots?
    Post edited by Tramp Graphics on
    I don't think they can do that. But I'll have to look at the morphs included. I didn't give them much of a look because I was concentrating on the texture creation process.
    I'll have a look for you.
    ~~Note to customers~~ My JeanZ addons will have DSON support. There was a misunderstanding when I uploaded the textures for testing. As I thought they was Genesis only and no Poser support was offered. I should have checked with Phillip in all honesty, but for some reason I didn't. The installers will be updated with the DSON files as soon as they pass testing. We just wanted to release the add-on alongside the JeanZ themselves for better promotion.
    The installers issue with D/Ling the files should be fixed now. :)
  • Ariella CandelariaAriella Candelaria Posts: 17
    JeanZ for Genesis Fits: says David 5?! So is David 5 coming?
    686 x 553 - 35K
  • the3dwizardthe3dwizard Posts: 495
    edited April 2013
    These have a TreadZ Tuck morph which will allow you to tuck them into the upcoming TreadZ for Genesis but this morph would hit the boots around mid-calf. There are some adjustment morphs to lower or raise the tuck morph but it will only go so high before it crunches. You can combine it with the KneeHigh and Expansion morph on the TreadZ to make the tuck a little higher (picture attached).
    BTW the V4 verison just has the TreadZTuck morph and not the tuck adjustment morphs.
    Hope this helps,
    Phillip
    500 x 650 - 101K
    Post edited by the3dwizard on
    Played with it some more. By taking some of the other fit morphs negative you can at least take it as high as the KneeHigh morph on the TreadZ.
    Cheers!
    500 x 650 - 96K
    edited April 2013
    Cheers!
    That looks pretty close to what I'd need. For the record, these are the boots the character in question wears. If you can get a "Legacy" format copy into the Genesis version, I'll be all over it.
  • SpitSpit Posts: 2,342
    I'd love to play but neither jeanz nor textures show up in DIM.
    That's strange, because they show up in my DIM fine... I don't know about the jeanz themselves though. :-/
    Maybe they broke again whislt I was asleep....?
    I tested DIM on another computer and they were there for my. If you haven't yet, contact support through the Help link and I am sure they will fix it for you.
    Cheers!
    Argghhhh. My bad.
    I noticed that they were still in my cart. I hadn't purchased yet. Sheesh. Got interrupted and forgot.
    ::blush::
    Spit said:
    Argghhhh. My bad.
    ::blush::
    Lol!
    Just an FYI, I was looking at the V4 version of the Jeans, and the link to the complete list of morphs is dead. It gives a 404 error.
  • cav8000cav8000 Posts: 0
    edited May 2013
    I just installed these Jeanz for Daz 4.6 but I cannot find the morphs anywhere or textures. Where are they?
    Never mind, I found them in the ACTOR category.
    Post edited by cav8000 on
    I have noticed a number of these secondary links were broken, I guess when they updated the store. I will ask them to fix.
    Yep, I put in under the Actor category. That way if you are using the Shaping tab the morphs will show up there if you have the JeanZ selected.
    Cheers!
  • atozedatozed Posts: 77
    Hello Mr. Wizard,
    I'd rather not use Genesis if I don't absolutely have to. Are you planning to release an M4 version at all? I'd snap it up in a heartbeat.
  • FSMCDesignsFSMCDesigns Posts: 12,851
    atozed said:
    Hello Mr. Wizard,
    use the V4 version and crossdresser to convert them, works very well.
    edited June 2013
    I just snagged the V4 version and dressed my character Tommie in them as button-fly "Daisy Dukes" (using Transfer Utility). They look great on her, but I do have one mild critique on the "Open" morphs. Only the Open 5 morph makes both sides of the fly open up, and, even then, the top of the waist band doesn't fold over at the fly. Open 1 only opens the left side, even at a full 1 or more. It would be nice if both sides would open as the buttons or zipper were undone.
    I wouldn't mind finding some more textures in different colors for the V4 set too.
  • efron_24efron_24 Posts: 478
    I have the Jeans for Genesis in Poser
    but it does not show up when I load it.
    There is "nothing"
    It does say it loaded.. but it is not there in the previews.. and in the renders
    Sadly
    what to do
  • Richard HaseltineRichard Haseltine Posts: 109,330
    Did you install both the Poser Companion Files and the Core/TriAx files? The PoserCFs are just the library files, geometry and textures are in the Core/TriAx installer.
