Iray Emissive lights with invisible props
in The Commons
Hi all!
I'm trying to light a scene tot render in Iray using emissive surfaces to give me some good lighting. Is there a way to make the emissive props themselves invisible in the render? I find that if I either make their surface cutout opacity value 0.0 or uncheck the "visible in render" property, the lighting also disappears... I would like the lighting to stay, but the prop to be "gone"... Is that possible?
Thanks a lot,
Me
Yes. Set opacity to .001. I recommend ghost lights since this product handles it for you, but it's not hard to do yourself:
https://direct.daz3d.com/forums/discussion/140701/making-the-light-invisible
https://www.daz3d.com/forums/discussion/127056/
Yes it's a quirk of the system that 0.0 doesn't do what you would expect. I usually use .0001.
Well, it *shouldn't* work at all even at .001, but a quirk of the system means it does. I've also had luck leaving the opacity set to 1.0 and putting a black map in the cutout opacity channel.
I'm not a scientist but Iray is supposed to be physically based. So something that has a visibility of 1/1000th of a percent (0.001) is likely too transparent for the naked eye (or camera) to perceive. Maybe on the order of a gas I guess? I suppose 0.0 doesn't actually exist in the "physical" world which is why it doesn't work. But that's only a guess :)
Or maybe it's a 10th of a percent I guess. My bad :)
Thanks for the awesome replies!!!!
