How to use SLG with Luxus?
Hi all,
how I can use SLG (GPU) with Luxus?
Hi all,
have you read through the luxus thread? There was a mention of SLG there. http://www.daz3d.com/forums/discussion/18543/
Oh and just to make things more clear, Luxus is plug-in, the more precise question would be does LuxRender use SLG. I know it can use the CPU and GPU at the same time in Hybrid mode but you do need an OpenCL compatable graphic card.
Quotes from the big thread concerning SLG:
SLG stands for SmallLux GPU, and is a horribly cut-down version of the real deal. Because it's entirely reliant on the GPU, everything it requires must fit inside the Graphics memory, meaning it often reduces the texture size making most objects look horribly basic. It's decent enough if you're only using Lux's own materials, but they're not all fully supported and probably never will be since hybrid is really the way things are heading.
There are workarounds to get SLG to work under Luxus, but I wouldn't recommend them as the material settings will likely cause your system to freeze.
Thank you very much Szark, Kerya and HeraldOfFire for the detailed informations! This helps.
Kerya went that extra mile to dig out those quotes, thank you Kerya.
HeraldOfFire thanks nice explanation.
Here is someone who figured out how to use the extra settings and the Beta 1.3 LuxRender
-> http://www.daz3d.com/forums/discussion/18543/P165/#273349
