Problem with Iray - transition between solid and transparent object
Hi,
I've tried to make a scene with a character (G8F) trapped inside a block of a semi-transparent substance, but when I render it seems Iray cannot make a decent transistion between the solid body and the transparent block. The render always shows up with a line of invisible dots along the transitions. I've tried to make the block a variety of substances (water, ice, wax, rubber, etc) but with the same result each time.
The attached image is a cutout of the whole render (it's kinda explicit :O) but you can see the white line of transparent dots.
Does anyone know how to fix this or why it's happening? It does not occur if the block is solid.
  • FishtalesFishtales Posts: 6,224
    To me that looks like reflection/refraction and it could also be that the light is too bright.
  • I tried to turn light intensity way down, and I also tried to turn down enviroment intensity and enviroment map. It got a bit better but not quite. Then I tried to remove all lighting and the enviroment map, and the problem is almost gone, but I can still see a tiny line in the transition areas...
