Looking for a Stove
in The Commons
I'm looking for an old cast iron wood burning cooking stove with a stove pipe that was used back in the 1800s and early 1900s. I've searched everywhere to find one that I can use in DAZ Studio, but I haven't found one anywhere. Has anyone seen one? Please see the attached picture. I'm looking for something sort of like this.
https://www.daz3d.com/pioneer-kitchen
Not really the same but it's the only similar item I can recall.
There's this: https://www.daz3d.com/coal-stove
Maybe you could increase the size by upping it's scale on the X-axis or something. :)
I have that coal stove and scaled it up.
Think it might work?
https://www.cgtrader.com/3d-models/household/kitchenware/aga-stove
https://www.cgtrader.com/3d-models/interior/kitchen/wood-or-coal-stove
https://www.turbosquid.com/3d-models/antique-stove-oven-3d-model/814975
https://www.turbosquid.com/3d-models/cookstove-stove-3d-model/510296?referral=The_Dodger
https://www.turbosquid.com/3d-models/max-rusted-stove/672845
https://www.turbosquid.com/3d-models/3ds-max-iron-stove/439755?referral=The_Dodger
Note: obj can be imported into DS
That Pioneer Kitchen one is about as close as I know of. It's later, like early 20th century, but while there are a number of the pot-bellied stoves like the one above, those were primarily heaters, rather than cooking ranges -- although you could cook one pot's worth on them. Or keep a kettle hot.
As one might expect, there's at least one on Turbosquid. But I didn't even check the price.
Actually, I'm rembering another one like the one in the pioneer kitches in a freebie pack called something like 1910 Kitchen. I think it was by Ockham.
This one? http://www.sharecg.com/v/47345/related/11/Poser/1910-Kitchen
The 1910 Kitchen is a good one. Not exactly the one I'm looking for, but it's the next best thing.
Thanks so much for the tip. It will work just fine for what I need.
It may sound silly, but there is one in the fairytail collection
https://www.daz3d.com/fairytale-collection-redhouse-cottage-interior
Yeah, the general shape of the Ockham 1910 stove, and the pioneer kitchen ones are reasonably close, if not perfect. They are later, and enameled, but one can use shaders for the iron.
I'd forgotten about the one in the fairytale cottage. It's clearly European, and I suspect that you'd need to extend the stovepipe once you pulled it out of the enclosure, but yeah, that very well might work. And since it's a PC item it's reasonably cheap.
It's also old enough that you might need to use shaders just because the original textures are likely to be very low-res.
