DAZ Dragon 3 - Eyeball texture is missing
wintoons
Hi Guys
I need your help.
I purchased the DAZ Dragon 3 model, but when I render it, the eyeball texture is missing.
Has anyone had this problem before? I need to fix this.
Thanks
Winton
I had that happen. If you go to the Surfaces tab for the Dragon and set 'Opacity Strength' of 'Eye Surface' to 0%, then the eye shows up.
Or change the Eye Surface to a Thin Glass. I read that somewhere on the forum. It gives it a nice reflection besides allowing you to see that eye.
Yes, if you're doing an Iray render, the problem is that the eye materials aren't Iray — they're custom 3Delight materials, so they don't auto-convert very well. Changing the Eye Surface material to the Iray Thin Glass is a good quick fix, although a bit more tweaking can give an even better result.
Thank you everyone! It worked out well. :)
