One click method for saving a magnet pose as a morph? SOLVED
Well OK, two or three clicks is OK too.....
Is there a simple method within DS of saving a (clothing) pose created by adding a magnet(s), as a morph? Poser has a simple "Spawn as Morph" function, surely DS has something similar without having to export objects (remembering to make everything else invisible first and then making it visible again after applying the object using MorphLoaderPro) and also having to deal with mesh resolutions and changes caused by the fact that the clothing was conformed to a morphed or scaled figure... blah blah complex annoying blah blah.....
Surely there is a simple process without needing to go outside DS of just saying "OK, that looks like I want it... now save it as a morph so I can delete all the magnets. Click, done!"
Window>Panes(Tabs)>dForm has a Spawn Morph button.
Thank you Richard, that is exactly what I was looking for.
