DForce on a mesh
hello guys,
first of all: thank you Daz for dForce!!!
I’m having trouble applying dForce to a mesh. The final result I wanna achieve is rendering a cilinder that  has to behave as if it was made of rubber, while I’m only able to make it behave as if it was a piece of fabric (it renders as an empty sleeve)..
I’ve tried to manipulate density, stiffness and other parameters but all I get is fatal crashes or mesh explosions!
anybody has succeeded in this?
  • dForce is (currently) a surface dynamics simulator, not a solid object simulator. You might be able to improve the result by adjsuting the surface settings to make it much stiffer, but I have had undesirable results when pushing those values high (presumably the simulation accumulates a lot of spring it can't dissipate and the mesh explodes)..
  • That's exactly what I'm experiencing... exploding meshes!
    Maybe weight maps could help? I've never done this before but I've seen there's some more information here https://www.daz3d.com/forums/discussion/203081/dforce-start-here#latest
  • LeanaLeana Posts: 12,845
    Turning off self-collision often help with clothing explosions.
  • I can't offer any conrete advice (which is why I didn't mention it in my first post) but a Dynamic Surface Add-On could add internal support - not the same as solid, but it might be close enough.
  • Try parenting the object inside a stiffer, transparent cylinder to constrain it, and place a stiffer cylinder inside it to keep it from collapsing in on itself.
  • barbultbarbult Posts: 26,393
    What is a "Dynamic Surface Add-On"???? I can't find any information on what it is or how to use it.
    It's one of the options when adding a dForce Modifier, or in the enumeration control on surfaces, but I don't have any solid information other than it is intended to allow adding structural elements to help shape draping items.
    Thank you Richard and Chohole. Dynamic Surface Add-On still sounds kind of mysterious. If you come across a tutorial, please post a link.
  • Ah, that was there last time I looked but I had forgotten all of the infromation. Sorry.
