How do I apply make up ?
AJ2112AJ2112 Posts: 1,417
edited April 2013 in New Users
Now, I'm confused in the surface area. Lucrezia comes with make up, but I can't find anywhere. When I click on Lucrezia full mat, Genesis turns into Lucrezia with black areas all over her body. Thanks for any assistance.
Post edited by AJ2112 on
  • SzarkSzark Posts: 10,634
    edited April 2013
    Taken form the product page
    •5 Make Up Options
    ◦Pink
    ◦Red
    ◦Blood Red
    ◦Deep Pink
    ◦Black Red
    •6 Eye Color Options
    ◦Dark Brown Blue
    ◦Ice Blue
    ◦Ice Green
    ◦Red
    •3 Nail Color Options
    ◦Natural
    ◦Black
    ◦Red
    •2 Tattoo Options
    ◦Arm Tattoo
    ◦Belly Tattoo
    which means they should all have a Preset loading Icon that you Apply to the character when selected.
    Post edited by Szark on
    There are a few reasons why you may be getting black areas. The most obvious is that you're using the wrong UV set for the character. Lucrezia might be utilizing Victoria 5's UV set, in which case you'll have to own Victoria 5 to use the textures which come with her otherwise they simply won't fit.
    The other possibility is that for some reason the preset isn't setting the UV map correctly. If you're confident the textures are Gen4 compatible, you can manually change the UV set in the surfaces tab to Victoria 4 by selecting the surface tab, clicking Genesis in the list and changing the UV set in the drop down.
  • AJ2112AJ2112 Posts: 1,417
    edited April 2013
    Hi Herald, here's image to show what I'm sharing. When I apply the full Lucrezia mat, to Genesis. Surface tabs all state multiple ??
    400 x 312 - 37K
    edited April 2013
    You can select individual surfaces to find out what UV's settings it's using. Select all of the skin surfaces and they should be using a single UV set. With that image though, I'm pretty convinced it's designed for Victoria 5. My guess is you don't have the necessary UV maps to use the skin.
    Post edited by Herald of Fire on
    edited April 2013
    Thanx Herald, now observing complete image, looks like mat does not fit Genesis properly, definetly V5 :-S
