5+ minutes to Load GEN3 Female
SLoTH_XVX
It is taking 5 minutes for Studio to load Genesis 3 Female base....this can't be normal. Can anyone help me determine what is taking so long to load her?
I have attached a copy of my log after loading her....but I am not sure what to look for to detrmine where to look for issues.
Thanks in advance for any help or direction you can provide.
Post edited by SLoTH_XVX on
1: How many G3F figures do you have installed?
2: What type of hard drive?
Drive is not the issue (IMO), other Genesis (8) figures load in a reasonable amount of time.
If I had to guess I have over 100 characters installed for GF3.
I have got hundreds of G3F chars installed, it takes less than 2 mins to load her up. 5 mins seems very excessive.
My thoughts exactly.
Oh! One thing I thought of. Are you using the drag drop method, or the double click method? For some odd reason, drag and drop takes longer to load than double click for me.
I always use double click.....but have tried the D-n-D (Drag-n-Drop) method and no significant difference between them.
Darn, I am all outta ideas.
Does it load any faster into an empty scene than the one you are working in? I've noticed that for whatever reason some larger scenes I have will have extreme loading times, whereas others load up right away.
The scene was/is completely empty....no lights, props, other figures...nothing. Just GF3 (base figure), first thing loaded into the scene. .
I suspect its all the duplicate formula & could not find property errors which are showing in your log as each error seems to slow things down
Pesonally I only keep in the content folder what I need for the current project. Among other things, this speeds up loading and helps to avoid duplicate formulas in some extent.
EDIT: I see your log is very messy. In general when you get an asset it is a good idea to test it just to see if it gets errors in the log. It may be dependencies on assets you don't have and/or missing updates on assets you have and/or simply a bug. DIM should update automatically.
For example, personally I get a dependency error on PHMEyesIrisSize every time I load a scene with the G3F. So I updated G3F and I checked it and the Iris Size morph doesn't exist. So I know it's a bug in G3F and I simply go on with it.
One error caught my attention:
G:/My Library/data/DAZ 3D/Genesis 3/Female/Morphs/Zeddicuss/Z_Da_Bomb_Expressions/Z_DB_11.png (1,1): Syntax error - expected '{' or '['Try removing this folder "G:/My Library/data/DAZ 3D/Genesis 3/Female/Morphs/Zeddicuss/Z_Da_Bomb_Expressions" to see if this fixes the error.
HTH
Jag11, this helped TREMENDOUSLY!
Knocked the time down from 5+ minutes to just under 2 minutes! Thank you
Padone
Thank you for the suggestion but only loading the content I am using in a scene would severly hamper my work flow as most of the time I browse through the content I have to find the 'right' item.
Tottallou
I will have to search through the logs for additiona 'errors' and see whether cleaning or clearing those out helps even more. Thank you for the tip.
Took some doing but I have removed all the troublesome 'duplicate' formulas from my content and now she is loading in just under 2 minutes without 'errors'.
Once again thank you each for your help!
Under two min is still long. Mine loads in 10 seconds, whether its a textureless base shape or a scene subset loading up the hair and textures plus dialing in all the used character morphs
For me, G3F loads in 2 minutes. I have over 50 figures. I've contacted support. Started several threads over time asking if anyone had any solutions. I've re-installed several times. I even got a brand new machine with new SSD and it did the same thing as I added more figures. Even with a bare bones install with zero figures, G3F still took 20 seconds to load.
Mine loads in 2 seconds.
2017-10-19 20:07:03.577 File loaded in 0 min 2.4 sec.
It should be interesting to see the log file to see whay others take so long to load a figure.
There's nothing unusual in the log file. I've gone over it and even sent it to the devs. I was told all sorts of things. Like it wasn't installed on the C drive (I reinstalled on C and it made no difference). It was on an external drive (it wasn't). I had to re-install (that made no difference). On and on. I'm even using an SSD. But nothing was ever found in the log file. I did a completely new install on a new machine. Same thing.
G2F and G8F load fast though. It's only G3F.
The time incrementally goes up as I install more and more figures for G3F. I even ran a Windows API Spy program to time the different function calls and it seems it's all morph related. It's just slow loading all the morphs. I also found that it keeps checking for registry keys that don't exist. These are somewhat slow. But I added most of them and it didn't seem to change anything.
Loading a character with morphs is single threaded. So if you have lots of cores running at a slower clock speed than a CPU with fewer cores at higher clock speed that could be a difference people see. Also loading morphs causes a lot of file I/O which can have all sorts of variables based on type of disk, state of current disk cache, antivirus/antimalware tools that monitor file access, etc.
What does "exclude all other libraries" mean? Where are these libraries?
I doubt it's your problem, to be honest. Do you have more G3 characters than the others currently installed?
