View Controls issue with City Limits Layout
KnightTek
Hello! I have noticed a problem when I use the City Limits layout in DAZ Studio 4.9 and also the 4.10 Beta. When I have all panes hidden, the view controls show normally but when I open the left and right panes, the view controls become hidden instead of sliding to the left to remain visible. (please see attached screenshots)
This behavior was not present in version 4.8 or the early version of 4.9 (at least for me). Has anyone else encountered this issue and if so, is there a fix or workaround? Or, does it require submitting a bug report?
Thanks!
Close the Shader Mixer and Shader Builder panes.
Richard, you are awesome! I did not think of closing those panes. Now, all is well. Thank you very much!!
I have not used that Layout because of the same issue, thanks!
and any others you have open except Render Library. By the way, you can kind of get around it by having View open from Window> Panes> View but it is better to close these other panes especially if you don't use them often. I don't even know how yet. :-D
