Victoria 4 Skinshader from 3DLight to Iray
Illidanstorm
Is there a skinshader for V4 that converts the 3DLight materials of the skin so I can use them in Iray?
Illidanstorm
DS should convert them at render time, or you can select teh surfaces and apply the Iray Uber Base shader (from Shaders>Iray). Of course those won't be optimised, but if you manually apply the base shader you can adjust settings - look at a figure already set-up with Iray materials for an example, but bear in mind that it's unlikely that a Victoria 4 character will have all of the map types used by many Iray set-ups.
