Where are the iray blood stained shaders?
Looking for blood stained shaders for iray.
Like, there's blood stains on a shirt. I have a dirt iray shader, but I can't figure how to turn the dirt patches into blood stains. lol
I would think this to be a hugely popular product(s).
I own quite a few that put blood on the people themselves, but nothing that puts the blood stains on the clothing.
I do have a few outfits with blood stains, but not a dedicated shader.
Searching the store led to zero results.
Weird.
  • BeeMKayBeeMKay Posts: 7,019
    This works fine if you convert the surface to Iray and adjust the settings a bit: https://www.daz3d.com/gore-dom-for-daz-studio
  • dragotxdragotx Posts: 1,147
    Weird.
    You might look at this one:  https://www.daz3d.com/horror-and-gore-iray-shaders
    I used it in https://www.daz3d.com/gallery/#images/443591/ and https://www.daz3d.com/gallery/#images/443586/ on both of the outfits.  Those are also straight out of the box with no adjustments or fiddling, i'm quite sure better results can be had by playing around with the settings some.
  • Griffin AvidGriffin Avid Posts: 3,822
    Nice renders. I Have that and figured it'd cover the surface 100% and make the objects look like 'they were made of the material'.
    Didn't realize it could do some areas on, some areas off.
    That appears to be the answer. Thank you so very much.
  • FSMCDesignsFSMCDesigns Posts: 12,845
    Weird.
    Thanks for the link, wasn't aware of that product.
    I didn’t know it would work with Iray. Interesting
    It has ones that do full coverage, but it also has ones buried that look like spotty globes, those are the ones I used.
    Weird.
    Yeah, I almost missed them when they released too.  Judging from the responses to a thread I made asking the same thing, apparently a lot of people did.
    The one I posted?  It's got Iray right in the name
    edited October 2017
    No, this one.
    Rendo also has gore shaders for iray
    (Link removed by Mod)
    Post edited by frank0314 on
  • FWIWFWIW Posts: 320
    How do you convert a surface to iray?
  • frank0314frank0314 Posts: 14,734
    there is a shader that you just click on to add to Iray but you will have some adjusting to do. I can't think of the name of the shader off hand though. Hopefully someone else remembers.
    It's probably the Iray Uber Shader, it's under Shades > Iray > Uber > the icon with the daz logo (can't remember what the pack is called, and I'm already in bed or I'd go check, but it's the official one that comes with Studio)
    Oooh! Okay I just saw that one, I've been trying to figure out what it does. Neat! Thanks
    Thank you!
  • 3Diva3Diva Posts: 11,981
    edited October 2017
    I don't know if this will work for your needs, but it looks like there's a new Blood and Dirt product in the store: https://www.daz3d.com/ultimate-blood-n-dirt-for-genesis-3-male-s
    Post edited by 3Diva on
  • Oooh! Okay I just saw that one, I've been trying to figure out what it does. Neat! Thanks
    Post some pics! Id love to see some gore-dom in iray!!!
    edited October 2017
    Actually, it is a LIE preset, so it can be used on any surface. When you use it out of the box, it can have some unwanted side effects due to displacement and the colouring is not very good.
    The upper arm is "out of the box", the lower arm has adjustments for Iray.
    Here's what I did:
    • identified the LIE temp map (In the render temp folder)
    • applied the Temp map to translucency and transmitted colour (replacing the maps there)
    • in Displacement, reduced the minimum/maximum from .25/-.25 to the default .1/-.1
    A problem is the seams, though. All is fine as long as you use the same map, like in the arm example, but if you have seams between arm and torso, it won't match any longer. That's a normal problem with textures, but I thought I'd mention it, anyways.
    2600 x 1462 - 725K
    Post edited by BeeMKay on
    Diva, looks real good, but it looks like another- "only on the guy"
    We need something for clothing.
    edited October 2017
    Addendum to my previous post - here is that same "running blood" shader applied to G8M shirt that comes with Iray native surface. The only adjustment was reducing the displacement max/minimum.
    2600 x 1950 - 973K
    These look great BeeMKay.  To be sure I am correct, you are using
    and NOT https://www.daz3d.com/horror-and-gore-iray-shaders
    Correct?
    Yes, that is correct. This is the "old" gore-dom shader for 3Delight.
    Bee, I've had that product forever and completely forgot about it! would never have thought i'd get it to work in iray - THANK YOU!
