mcjribbons2k17 - Build things ( extrusion ) in Daz Studio, PC and MAC !
mCasualmCasual Posts: 4,607
edited October 2017 in Freebies
it's the next-level version of the 2010 script mcjRibbons
the principle is simple, animate a group of null nodes in space and the script creates an envelope around those paths
https://sites.google.com/site/mcasualsdazscripts8/mcjribbons2k17
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited October 2017
    more images from the making-of
    800 x 800 - 220K
    888 x 888 - 500K
    1920 x 1080 - 318K
    edited October 2017
    Modeling a Hard-Turn Frame Corner in Daz Studio Using mcjRibbons2K17
    1 - Start mcjRibbons2K17,
    2 - Select the "classic_reeding" shape,
    3 - Set the "Mold Width" at 2
    This will give us a 2cm x 9.9 cm shape,
    4 - Click the "Create Profile Node Group" button,
    5 - Exit mcjRibbons2K17
    6 - In the scene find a node named "Profile_classic_reeding"
    The Profile Group Node contains 45 child nodes named pixx0 to pixx44
    For better visuals, select all those nodes and scale them down to 3%
    7 - Select the "Profile_classic_reeding" node
    8 - Set your Daz Studio timeline (animation) frame to frame 0
    9 - Click the keyframe button
    10 - Set the timeline at frame 1
    11 - In the parameters tab, change Z Translate from 0 cm to 49.5 cm
    this would create a 49.5 cm reed moulding but we want to turn a corner
    12 - Still at frame 1, In the parameters tab, change X Rotate from 0° to 45°
    there's a problem, this would narrow the width of the moulding,
    in this case sin( 45 degrees ) = 0.707. so we need to scale it up by 1 / 0.707 = 1.4142
    13 - Still at frame 1, change Y Scale from 100% to 141.42%
    14 - Click the keyframe button
    15 - Set the timeline at frame 2
    16 - change Z Translate from 49.5 cm to 50 cm
    17 - Click the keyframe button
    we made 2 cuts with a 0.5cm spacing because we want to 'harden' the corner
    18 - Set the timeline at frame 3 19 - change YTranslate from 0 cm to 0.5 cm
    20 - Click the keyframe button
    21 - Set the timeline at frame 3
    22 - change to YTranslate 50 cm, Y Scale 100%, X Rotate 90°
    23 - Click the keyframe button
    Since by default the timeline playrange covers 31 frames...
    a 31-rings tube would be created, but we only animated frames 0 to 4 so ...
    24 - Set the Timeline's "Total" to 5. The 'Range' is now frame 0 to 4
    25 - With "Profile_classic_reeding" still selected Start mcjRibbons2K17
    since this node is branded as being a profile node group, mcjRibbons2K17 will take care of selecting all the 45 pixx nodes for you. That string of nodes is properly ordered so this can be done automatically. If you use you own custom profile nodes, you will need to select your pixx nodes one by one in the correct order. They wont need to be named pixx and can be any type of node, For example, the rear tires of an animated car.
    26 - click the "Build-Save" button, save it as thatsurewasalongreed.obj
    27 - click the "Load Last Built" button
    you modeled something in Daz Studio! whowooddathott !
    mcjRibbons2K17
    this tutorial
    https://sites.google.com/site/mcasualsdazscripts8/tutorial-making-a-frame-using-mcjribbons2k17
    1920 x 1080 - 441K
    800 x 800 - 116K
  • More good stuff, thanks.
