Adding to Cart…
OK what was in the RC that is not allowing me to remove it. Went all the way to add/remove programs and and cleaned the registry and when I downloaded and reinstalled my old 4pro it went straight to being the RC again.
Did you happen to clear out your roaming folder as well?
My what? I have beta tested before and this is the first time I have had this happen, My issues with the RC were very minor overall [ Compared to the ones with the new store and website launch clusterfrick } I am working on a couple of things and I really need the use of my plugins that aren't usable in the RC
DAZ has a folder in C:\Users\YOUR NAME\AppData\Roaming. Occasionally things in there can cause an issue. Every time I do a fresh install I empty mine out. That way there is no chance of there being an issue. I have to do that with Poser or it messes everything up on install.
I will give that a try thank. I love the speed of that RC but still needs more tweaking
I haven't had the chance to use 4.5 yet. I use it for development and with the plugins not working its not of real use to me yet.
When you install an item which has metadata, the installer puts an entry in C:\Documents and Settings\[username]\AppData\Roaming\DAZ 3D\Studio4\RunOnce\Metadata -- that's what triggers the dialog box when you start DS4 asking to import Metadata. If you delete that entry it won't prompt you for it.
Did anyone see this?
You can run, but you can't hide. :) Thanks for the info.
Okay, I just realized something about my problem. I've noticed that the issue I'm having is occurring specifically with Auto-fitted clothing, most occurring with Gen 4 clothing. Before I took up this Candidate testing, my issue wasn't this specific.
Could it possibly mean that there's something that needs to be updated with the previous items as the Gen 5 Metadata?
Question: is it possible to stop that writing to C:\?
As I don't use SmartContent I could do withouth Metadata at all.
As I do have a brandnew SSD harddrive (fun!) I try to stop every writing access that is not necessary.
Antivirus updates are necessary, Metadata are not, for me anyway. ;-)
Is there a post (or wiki page, or whatever) with information about the mysterious Push Modifier? I saw it mentioned in RC1 and I can add it to things... but it doesn't seem to do anything that I can detect, and I can't find any new dials under Properties, so I think I missed a step.
Ooh, I'd be interested in an answer to this also....:)
Hi everybody
Did everyone test the new Duf Format?
I must say I'm not very happy with it for the moment.
- First it's slower than the old DAZ Format for reading and writing scenes
- Second point is that it is not always "lightweight". I loaded a few scenes I made with DS4 and saved them back and the new files are way larger than the old ones (about twice)
Did some test and here's what I found out :
1°/ loaded Genesis and some V4 hair. Used CCT to conform the Hair to Genesis then saved. File size ~ 17 Mb
2°/ Saved the Hair as an asset in my Library then saved the scene again => File size is 76 Ko
So if I'm right one has to save all the V4 Stuff again in Duf format to benefit from the lightweight
Is it the same for all you guys?
[Edit] Only 64 bit version is slow on reading and writing. 32 bit is OK
I looked high and low and eventually found it.
1. Select a model in the Scene tab.
2. On the Scene tab's "Active Pane Options", select Edit>Geometry>Apply Push Modifier.
or from the Edit menu, Figure>Geometry>Apply Push Modifier
Edit: In the Parameter's tab, General section a "Mesh Offset" dial is added to adjust the offset.
Yes, the .duf file is lightweight if there are assets it can refer to. That means .dsf files for native content, or Poser files for non-native content. It can even store the original content and the conversion settings for AutoFitted clothing. But if you rig something with the Content Creation Tools the rigging information (geometry, joints, morphs and weight maps) have to be somewhere - if they aren't saved out as dsf files then they have to be embedded in the .duf file.
The worst I'm getting is that I try to save my older Scene files as .duf's the program crashes, pretty much telling me that I may very well have to recreate everything all over again... :down:
And as for the files that I created and saved in the .duf file type they take quite a while to load when I open them...
Don't feel bad.. I am loading one of the new duf files and its taking 10 minutes to make any changes as simple as making something visible or not. Goes straight to ( not Responding ) the minute I click something. And yes I am running a 4-4 64bit system
8 GB, 64 bit here. My laptop is a customized gaming/3D development build, too... :down:
crashed on the resave >,<</p>
How long will this RC last and what is the download file size?
I ask because I'd like to test, but not if it's going to waste a huge chunk of my limited bandwidth allowance. The last version 4.0.3.47 was almost 1Gig, most of which was of no use to me.
Thanks Richard. Do you have also the 64 bit version beeing very slow?
I haven't had much time to play, but in as far as I have I haven't noticed a big difference. Note that although the bare Poser assets are enough for a .duf scene to open correctly, converted assets are created and saved so it's possible that if you save a scene from the 64 bit version of DS and then from the 32 bit version the latter will be quicker as it has less to do - but I'm not certain that that is the case, even if it matches what you did.
I'm just learning at the moment and upgrading to this has really set me back. The main thing I'm playing with at the moment is head morphs - so, imported the same way as before and couldn't find it anywhere in the head parameters. Found from an earlier post it's no longer in the parameters for the head, but in the ones for the figure itself - and guess what? It's stopped working! Has no effect at all! Actually, I've just realised and tested - my morphs didn't even load with the advanced loader, only with the pro.
Plus, what is with trying to cancel a render? I cancelled a render after 3 minutes and it didn't close off until 3min 10 secs later, virtually locking the computer up in the mean time. Thought it was a fluke, but no - takes ages every time.
I'm beginning to wish I had waited too :-(
Cancelling a render has to wait on 3Delight - if a single bucket is taking ages to render then so will the cancellation. If this is a frequent issue it may be worth lowering the bucket size - but there's a slight speed penalty for doing so.
Hello,
I'm experiencing some problems with the .duf saves. If I dial some morphs in a character, save it and reopen it, everything is fine. However, if after reopening I set any of those morphs back to default (zero), save and reopen, the zeroing will be ignored, meaning, the dials are back to where I've set them before. Apparently, after a dial has been changed, the .duf file won't save it if its reverted to zero, I have always to use a value of 0.001 or similar to get it to save the value.
I'm using RC1 here, has this been fixed in RC2?
Enjoying RC1 32-bit so far. Faster renders, faster loads and saves.
A couple of things though...
1) Sometimes I will open a DS4 file I made with DS4Pro 4.0 and the maps are totally messed up. Reapplying maps helps but might there be a workaround? Maybe I'll check next time to see what mapping coordinates it's using.
2) I'd love to use Gen X, but it doesn't show up in my Tabs list. I've reinstalled more than once and it doesn't work. Might anyone offer a clue for this clueless user?
I'm downloading RC2 now so maybe there will be a fix for the above two issues. Here's hoping I don't pick up a bunch more. ;)
Thanks!
I asked the same question and it has not been upgraded to work with this RC
Thanks, Noshoba. That's a bummer, that is. I have all sorts of morphs I'd like to bring over, but since 4.5 wiped out my 4.0 install I guess I have to wait.
Is there any troubles in RC2 when using LOD for M4\V4 like in RC1?
