Adding Texture
dash2128
I am adding texture and color to this Prae-Miasa Hair that I imported, but- since it was imported manually- I'm not sure how to transfer the textures and hair color to the hair itself. Drag-n-drop doesn't seem to work, and no option to merge, seems available; unless I'm missing it.
How do I add the textures (and color) to the hair?
Have you tried selecting all the surfaces in the Surfaces tab first? (Not always needed but sometimes is). If those are Poser materials presets, they might not work in DS. Are there any other presets in the list?
If the presets aren't working, you can manually add textures via the Surfaces tab. (Windows->Panes->Surfaces if it's not already at one side).
Put the colour map in the 'Diffuse' channel, the bump map in the 'bump' channel (if Iray - you'll need to set the strength) and specular map in the specular colour/strength channel depending on which it is).
If you've imported it manually as an obj, it'll default to having 3Delight materials shader - If you want to use Iray select the object, select all the hair's surfaces in the Surfaces tab, and apply the Daz Uber shader.
Yes, that seems to have worked, thanks!
