how to save g8f bikini auto g8m morph to bikini morph folder?
MistaraMistara Posts: 38,675
i did the dialog thing to fit G8F's bikini to Michael 8.
how do i save it to the bikini, so is ready to go for next time?
TYsmiley
    Save out the fitted bikini in obj format, base resolution, and reimport it to the default bikini via morph loader pro. Once loaded and working go to file > save as > support asset > morph asset.
    I've never tried to create morphs from autofit, but that's the method of doing it when you're morphing things in a modeler.
  • I think you are going to want to save the bikini itself as a figure, not just make a morph.
    i've been saving Michael's auto'd skimpwear as a product.
    seemed silly, was wondering if i was missing something obvious to save just the morphs.
  • You can save morphs, problem is autofit does not just make a morph it also rerigs the clothing to the new skeleton. So if you just save a morph then all you can do is morph the clothing to Michael's shape while on Vicky because the skeleton is still female.
  • File>Save As>Support Assets>Figure/Prop Asset, assuming you mean you AutoFitted it.
    it starts with the dialog that says 'who was this designed for '
    does this re-rig?
    not sure on the terminology correctness.
    technically, i didn't use TU, but maybe the dialog calls TU.
    does this re-rig?
    Yes, when you fit something designed for the female skeleton onto the male skeleton it rerigs the object.
