CPU / Rendering
Is there a easy way to specify to Daz Studio how many cores/threads to use on a multi-core CPU when rendering? Is it either all on or all off? Not interested in methods that require a triple Ph-D in Computer Science and be proficient in C++.
Thank you
What operating system?
In Windows, you can do it in the task manager while the program is running. You will need to do this every time you open Daz Studio
In Windows 10:
Keep in mind when selecting CPUs that the even numbered ones (0,2,4,6,etc.) are your primary work horses, whereas the odd numbers are the hyperthreading cores (1,3,5,7,etc.)
Hyperthreading cores are generaly less powerfull than the main cores.
Intel Core 2, and AMD Phenom processors do not have hyperthreading, so all threads are full power CPU cores
On AMD FX processors their version of cores is similar to hyperthreading, all cores have the same processing power but each cluster of two share some components so when setting the affinity make sure to take that into account [CPU setup = (0,1)(2,3)(4,5)(6,7) each comma repersents shared resources]
Perfect! Thanks James!
