I Need Patience and Fortitude
robkelk
And not just because I'm using an older computer. :-)
While the entire façace of the New York Public Library main building would be lovely, what I need in the short-to-medium term for a render is Patience and Fortitude, the lions who "guard" the Library. Are models of them available (legally) anywhere? Characters would be wonderful, but props will suffice...
(They're rather distinctive, and the person I'm doing the render for has an eye for architectural elements, so simply re-texturing the Millennium Big Cat probably won't work... unless there's a P&F morph for the MBC out there.)
Post edited by robkelk on
Google Sketchup warehouse maybe? I will look
trying not to cheat and use iClone 3dxchange only the collada download
Daz studio with opacity turned un on all surfaces (too many ngons)
Carrara, (more forgiving of ngons)
no lions
easy in iClone but lions kinda 2Dimensional
in studio again using Ruby obj exporter plugin, still ngon faces missing
If this is for 2D illustrative work, I would have thought that a little retouching of Predatron's lion statues would work. If retouching is out of the question you still might be able to get away with the models which aren't that far off. The plinth isn't quite the same, but that's just rectangular blocks so pretty to easy to modify.
http://www.daz3d.com/lorez-lion-statues
I was not aware of them... thanks! I'll ask whether they're close enough.
