Error in lightining during render
I'm quite new to Daz and althought usually I can get a workaround most of the problems I encounter by doing some research, this one I can't seem to find answers anywhere.
I was trying out some new stuff I got from Daz Store a few days ago, being one of them the Render Sphere. I changed the background and removed all the lights that came with the product as I was only interested for now in trying the fog effect. When I decided to do the first test in Iray, I noticed I was both seeing the light from my back light and a black square from my key light. I found it odd because I was pretty sure I add turned off the render emitter on both, but went on to recheck it and in fact I did had switched it off. My second thought was that it could be something related with the Render Sphere so I went on to create a different scene without the render sphere but the same problem persisted.
Below I have a quick render of the first image and a screenshot of the scene setup where you can see what I'm talking about. My question now is, how do I solve this? Have I by mistake changed any setting that caused this?
Thanks in advance!
  • BeeMKayBeeMKay Posts: 7,019
    The Render Sphere was created for use in 3Delight, and doesn't work in Iray.
    When Ilook at your setup, at the posistion that has the square, you have a light source. You will see the light source in the render (imagine a physical spotlight). move that out of the frame, and the square should be gone.
