where is the d-former field?!?!
Toobis
in The Commons
Added a little primitive to my scene and I wanted to edit it using a d-morpher but for some reason I can't get the d-former field to appear anywhere on it??! any ideas? pic of it included.
well yeh I did that already but theres no d-former field.
I think your plane needs more Divisions so there is something to deform - i can get a field with 100 but not with 1
agreed. you need more than 4 vertices to deform it. Subd it and see if that helps
dGorms require real geometry, not virtual from SubD.
I think you're mixing terminology, the Field is there — it's the "three-way circle" made of thin red lines surrounding the D-Former base and "mushroom". If you mean the coloured dots, that's the Weight Display, and you only see the dots where mesh lines meet at vertices. Check the mesh divisions of the plane; if there's no mesh, there's no dots.
Sorry to reply late. I am not sure how to rectify this can anyone give me some more info on how to do this? preferbly with some screenshots as I learn better by example. Thankyou.
what do you mean divisions?!
yeh I thought everything had settings on the right I mean you are being too vague what do you mean??!?!
When you make your plane in studio - you can set the divisions (see attached)
Nevermind. Tottallou beat me to it.
Yeah, "when you make" is kind of important here.
Ohh okkkkkk gottit. So basically as long as its not 0 in divisions.
You would need at least 4 Divisions (as FNCDesigns stated earlier)
K thankyou everyone.
