North
Hi everyone
could you if is there any way to chang north direction in a scene? I can see how to change sun parameters and location coordinates, but north direction is always in the same position.
Thank you
Hi everyone
Thank you
If you click on FRONT in the box in the right hand corner of the window and then rotate the Dome by 180 then the camera should be facing North ( I think :) ) I'm sure it faces South by default.
Do you think dome direction is defining north direction? I'll try that idea, Fishtales. Thank you very much.
If you leave the dome at zero and the cube at front then it is facing South. You can also click on the cube so that it is showing REAR and the camera will then be pointing NORTH and the dome will be at default. The position of the sun will be set according to the lat/long and time settings. ( I think, I tend to just move things until it all looks right but that is my starting view :) When using one of my own images as a backdrop I know when, where and the direction I was facing and set the environment up using those parameters, lat/long, time and use the cube to point in roughly the direction, N/S/E/W or any points in between, and then tweak it all until the shadows match. )
