How do I remove legacy UVs?
I'm using some of Cayman Studios' wonderful scripts to add legacy textures to a custom morph G3. I now want to use a G3 texture again. Is there an easy way to remove the legacy grafts rather than adding the texture to each graft area? If I just remove them I'm left with gaps. I'm sure there's a simple way to revert but I can't work out how! Thanks in advance!
Remove the add-on parts either by deleting them or by fitting them to None - as long as they are fitted to the figure they will hide the existing faces in that area, even if they are themselves invisible.
Perfect! Thank you!
