Resetting axes
Quite often I find a prop has annoying axes of translation and rotation (ie they don't align to the axes of the prop for some bizarre reason). Anyone else have this? It makes it terribly difficult to position the prop where you want it because you have to "zig zag" it into position.
Is there no way to "reset" the axes on a piece of content?
If by 'axis' you mean the universal transform gizmo, then that's usually because the pivot point for the object is placed elsewhere. To fix it, click on the Joint Editor tool. This will show two new mini gizmos, one green and one red. Move the green one to where you'd like the new pivot to be and then go back to your universal tool. The transform gizmo has now moved to that point, which should make the prop easier to work with.
