Invite Thoughts on Substance Painter as Part of Work Flow?
2»
  • DUDUDUDU Posts: 1,945
    OK:
    Color: no problem...
    AO: ?
    Curvature:?
    Disp: Displacement channel?
    Metalness: ?
    nmap: Bump channel?
    Rough: ?
    What is the texture channel for each one?
    Thanks.
    edited September 2017
    AO is ambient occlusion. You don't really need it in Carrara, but if you want to you can multiply the color by it to artificially darken the color in some of the subtle shadows an object casts on itself. You'll have to experiment with how much of this effect you want, or if you like it at all.
    Curvature by itself isn't all that useful but you could use it as a mixer between two shaders in the color or reflection channel  Curvature shows how convex or concave the model is at any given point, so you could use it to add grunge/dirt in grooves or add scratches to "high points" on your model.
    Metalness is a black and white map showing where there is metal and not-metal. You would use that as a mixer: in the non-metal areas, you would use the color in the color channel and the rougness (inverted) in the reflection channel and in the metal areas you would put the color in the color channel, but with the brightness turned way down, and the color in the reflection channel (because the color map will drive both the intensity and the color of the reflections for metal).
    Disp is basically a normal greyscale bump map (close enough anyway). You can probably use it either as a bump map or to drive actual displacement.
    nmap is probably a normal map. You can use that in the bump channel.
    Rough is roughness and is how sharp the reflections are. Something like mirror glass would be 0/black/sharp reflections and something like rubber would be nearer to 1/white/very diffuse and blurry reflections. There isn't really a direct equivalent in Carrara. I usually invert it and use it in the glossiness channel. I also use the inverted version in the shininess channel but you need to play with the brightness on a case-by-case basis.
    For a slightly different method, see @TangoAlpha's post on the prior page https://www.daz3d.com/forums/discussion/comment/2864286/#Comment_2864286 showing how he uses similar maps from Substance Painter.
    Post edited by MarkIsSleepy on
  • Oso3DOso3D Posts: 15,090
    I find Curvature and AO incredibly useful to build effects.
    For example, AO is great for having grime in crevices or weathered exposed surfaces.
    Curvature can do similar, but the layout is a little different.
    You can save out maps baked in SP, or change the Export to include them.
    I mention this mainly for Thickness map, which is great if you want a subtle effect that changes from a thick body to thinner limbs.
    He, thank you for your responses but in any case, it's the same eternal problem: UV mapping!!!
    I tried also SP a few months ago but I think that 3DC is more compatible with Carrara.
    Good evening (9PM here)!
    Post edited by DUDU on
  • magaremotomagaremoto Posts: 1,238
    edited March 2018
    very first test with substance PBR maps, unfortunately 1024x rez only
    more to follow
    4800 x 2700 - 1M
    Post edited by magaremoto on
  • DiomedeDiomede Posts: 15,393
    Thanks for posting these tests.
  • That's funny. I've been working on the same subject for a week now, and I'm more or less at the same point.
    edited March 2018
    another try with low res substance maps; in my brief experiece apart form displacement all the maps work fine in carrara but at least 3k res are needed; hard to find a map good for carrara displacement channel as yet
    3840 x 2160 - 1M
    What maps are you generating, and how are you assigning them in Carrara?
    well, typically to start I've been using this scheme and see what it comes out and eventually make adjustments:
    PBR albedo or diffuse > color channel
    PBR glossy or metallic > highlight channel
    PBR roughness (in some cases AO or both) > shininess channel
    PBR normal > bump channel (as a simple texture map too)
    PBR specular or reflection > reflection channel
    PBR displacement or height  (in some cases AO) > displacement channel
    as you know very important to tweak are the fresnel slider in the reflection channel (very low for metals or glass, up to 80% for very opaque materials) and the blur slider: you can use it with ease in presence of color reflections (i.e. gold), for specular maps I suggest to blur in prework to speed up render times
    of course I'm working on it only recently so any suggestion is welcome
  • It's very useful indeed ???? By the way, I'm working to implement Disney BSDR into Carrara. It's working quite nicely, except for diffuse Fresnel. There, I've got issues with the way Carrara is computing self shadow. In Lambertian diffusion, grazing angles are dark, so imperfections in self shadow don't show. With Fresnel diffusion, grazing angles are light and there it shows... I'll start a WIP thread about that new plugin.
    as stated in the guide too, the fresnel effect is related to IOR and in some cases to transparency and absorption (only metals behave as they can absorb only a little portion of light wavelenght); maybe you should try to play with refraction and transparency for lambertian diffuse materials
  • Philemo_CarraraPhilemo_Carrara Posts: 1,175
    edited March 2018
    Please have a look to section 5.3 of this document, you'll see what I mean by diffuse Fresnel for rough surfaces.
    Post edited by Philemo_Carrara on
    the Oren Nayar model could be useful? if I recall it points out that a sss layer could help  for retroreflective roughness, dunno how
    anyway can you post a sample?
