Lux light
Ali Bozis
How do i make a lux light in daz? Shouldn't there be a option to choose it under the parameter tab when i create a light?
Post edited by Ali Bozis on
Ali Bozis
With Luxus, you create a light, then go to the parameters tab menu, select "Luxus - LuxRender Light" and pick your options.
You can also set any surface to be a light emitter through the surfaces tab menu. "Luxus - LuxRender Material" and make sure to check the box that gives you light options.
