Diffuse map
Hi! :)
I search a lot on the internet but couldn't find a way to get maps (Diffuse, normal, AO, etc.) in my export folder. As far as i know, there is not really a simply way to get them, however I read that I can have the Diffuse map when I export from DazStudio (and maybe I can have the other maps by putting the diffuse/base color into Bitmap2Material). Is there an export setting that allows me to get this Diffuse map (or even the other maps :))?
Thank you in advance,
Hi Vidal
Is it a specific model you're trying to export?
Hi Prixat
Actually I tried even with "Basic Female" and didn't get the map(s) expected. Why? is it impossible with some characters?
Have a nice day,
Vidal
Hi
Thanks for the reply! Actually I even tried with Basic female but sadly got nothing. Why? is it impossible to get maps with some characters?
Have a good day,
Vidal
Not sure if this is what you are looking for but if you tick "Collect Maps" on the export object screen then you get the Diffuse Maps + Obj + MTL file in the folder you choose to export to (see attached)
Hi Tottallou :)
That's what I did, but these maps aren't the Diffuse/base color maps, isn't it?
Vidal
