Victoria 8, Victoria 8 HD, et al Load Error Message
Bitstream
I get an error message when loading Victoria 8, Victoria 8 HD, PD Duffy HD for V8, (and maybe others in the V8 realm...I don't know as I haven't tried them yet). I click "Ok" on the error message dialogue box and the figure seems to load okay (not sure if anything is missing or not).
The error message is:
DS Missing Files
Some assets needed to load the file were missing. The content may not work as expected.
The following files could not be found:
volumes/di2/online store/dtg/olivia v8/olivia.duf
I uninstalled Victoria 8 and reinstalled it, but I still get this error message. Anyone else experience this, and, if so, what did you do to fix the problem? I have no idea what the "olivia.duf" file is or where to find it if it's not part of the Victoria 8 files set.
Thanks for your help,
Robert
I had that, contacted the vendor of Olivia and they have released an updated file (file 1). If I recall correctly I manually deleted the install first befiore the update worked.
SimonJM,
Thanks for the input. Unfortunately, I don't have any Olivia characters. I wish I did, so I could do as you mentioned. What I don't understand is why a file called Olivia has anything to do with Victoria 8. Oh well. Hopefully there isn't anything missing from the Victoria 8 load, even though I get the error message.
Thanks again for your help.
That is the exact same message I got after I installed the Olivia character I bought from 'rosity.
@Tacit Illusion (R.A. Christian)
Olivia.duf would be found in your library in People / Genesis 8 Female / Characters / DTG / Olivia .
Take a look, what do you have to lose? Most of us have bought and installed something, then forgot about it.
I definitely don't have Olivia and don't get those messages.
