Genesis 8 Female Head Morph Resource Kit 2
Timotheus
Not sure if this question belongs here in The Commons or is better suited to Technical Help, but it's not really a technical problem....
Anyway, here goes.
This product, Genesis 8 Female Head Morph Resource Kit 2, is a merchant resource, and I plan to use it to help me create some custom characters for G8 Female. I'm a bit new to this, however, and want to make sure I actually put it to use correctly. I started with the developer Genesis 8 female and then used morphs from this kit to create my character. Once I have the character I want, can I simply save this as a preset? I guess I'm confused because it seems to work like the Head and Body Morphs packages you can purchase, except that the final end user also needs to own these. With this kit, that doesn't seem to be the case, but I'm just not sure. I want to be certain that I do all of this correctly.
Anyone know for sure? Any thoughts? Handspan Studios? Thorne?
Thanks for any assistance.
Tim
No, a preset can be saved for any product - in this case the Merchant Resouce license means you can export an OBJ (of the fuile figure at base resolution, without any attachments) and then load that as a single custom morph via Morph Loader Pro. You may need to make some adjustments, and you shoud check that your method of distribution is OK.
Perfect. Thank you!
