Felicity Jones (WIP) Morph
MGHSFAN2k
in The Commons
Trying to do a Felicity Jones head morph.... Any critiques or notes I can use to fix the head (I'm also using FoRender's JynEnso Character to help)
I'm not using reference photos when suggesting this, but I have stared at Miss Jones' face long enough, and I'd say that the first thing that stands out is her mouth. Or more accurately the lips. She nearly always has her front upper teeth showing, what some might call 'goofy' teeth (but I love 'em as they make her unique). To me that area is an important part of her face to get right as it can help tie the rest of the face together. Right now I don't see Felicity but I'll look again if you can woek on that.
BTW, thanks for mentioning Jyn on FoRender. I didn't know they'd done her as I usually avoid that site.
I agree regarding the mouth. Felicity's got a wide mouth relative to the width of her nose, and she thankfully lacks botoxed lips (which puts her at odds with the inspiration of many Genesis lookalikes). She's also got large (but not cartoonish) eyes.
Aside from the morphing, Felicity usually makes great use of eyeliner and that helps give her a distinct look. So be sure to choose a texture that plays that up.
Same here.
I can see a resemblance
Update: Going in the right direction or wrong direction? Any critiques?
You were getting warmer with the first post, now you're getting hot.
More teeth and her nose is a bit more angular/chiselled if that makes sense, not so soft and rounded.
But I'd say you're like.. very close!
there are teeth morphs if your interested
https://www.daz3d.com/easy-teeth-for-genesis-3-female-s-and-merchant-resource
https://www.daz3d.com/easy-teeth-for-genesis-8-female-s-and-merchant-resource
I'd say your getting closer. BTW, don't mention that other site. The last time I did, my post was removed.
This is for V4
aah that makes it bit harder don't think there are any for her earliest I can see is dental plan for genesis pity she looks nice old v4 still has life in her
I agree with Karuki - more teeth but it's definitely much closer than your other preview. I can see Felicity in there now.
I can't help you with suggesting morphs as I don't use V4.
I would not show the teeth, do that as a pose else it will probably mess up other mouth movements especially when trying to close the mouth all the way to show no teeth.
Bad news, I didn't save the progress of the last one so I had to start from the first one.... :-(
Good News, I tried to recreate what I did and I found to way to show the teeth, It might be a pose preset if choose to use it....
Minor Tweaks - Comments?
Much better on the mouth/lips, great job.
If I may I don't think her cheeks and cheekbones are correct. Yours appear to be too angular or sunk in, I don't know if there's a correct term for it, but it's most noticeable in your right hand image. To me her face is more rounded and that effect you have is achieved through make-up. There is some 'angular-ness' in her photos, so maybe reduce it a bit?
Here's an example of what I'm getting at.
https://hdwallsource.com/img/2016/10/felicity-jones-face-wallpaper-55006-56744-hd-wallpapers.jpg
http://s1.ibtimes.com/sites/www.ibtimes.com/files/styles/embed/public/2011/11/28/196646-felicity-jones.jpg
https://i.pinimg.com/736x/fb/b2/c1/fbb2c174f89000bbb0adeca9c28acd7d--felicity-jones-face-beauty.jpg
https://vignette4.wikia.nocookie.net/worstwitchw/images/1/1e/Feljon01.jpg/revision/latest?cb=20170403010759
You're getting really close now!
