Content will not load
TabianTabian Posts: 76
Hi there, can anyone please tell me why the grass or anything els in this tab will not load?
Any help much appreciated .
  • TabianTabian Posts: 76
    It's OK I found it....!
    edited March 2013
    As you can see these file type in content library,
    it say "material". and you tried to load matrerial files wihout prop (grasses or bench or envrionment asset)
    under poser content directory>material.
    you need to load these propin the scene,
    then select it.
    after that you can apply each material preset to the prop (figure)
    (of course you can not apply grass material to chair etc,, )
    then you may need to read me,, to check where prop or figure files are installed.
    and be shown in content library.
    usually,, if it is items for poser, you can finde under poser content> your poser content folda(my library etc)>props
    >vendor name or product name folda .
    there will be.these props .I think. and if there is scene files you can load all asset at same time,
    so you may better to check the product read me first. ^^b
    Post edited by kitakoredaz on
    Thank you...
