Putting G8 into a T-pose in order to smart prop G3 items to hands? - Solved
TJohn
Sorry if this has been covered somewhere, but can this be done? In the A-pose the smart props appear where the hands would be if the figure was in a t-pose. Is there an t-pose setting somewhere for G8? I haven't found it. Thanks.
Post edited by TJohn on
there was something about baking the rotations
Found one here. https://sickleyield.deviantart.com/journal/Tutorial-Convert-Clothing-G3-to-G8-G8-to-G3-686682065
But the smart prop still won't appear in the hand and has to be moved in the parameters.
Sorry it will work, just load the prop in the scene with the figure in the t-pose and unselected. Then you can parent the object to the hand.
she truly is the most backwards compatible
