Need help with Anneka she devil
Hi guys, I am new to daz and trying to play around with Anneka but her skin is mush darker in my renders than what I can see online.
As you can see in the second picture, I don't think it's a lighing problem, the scene is quite bright.
Could someone give me pointers as to how to solve this ?
  • LlynaraLlynara Posts: 4,772
    I would make sure you have the correct mats for the render engine you're using. Most stuff loads with 3Delight textures unless they're Iray only. Here's a render I did of Anneka, ported over to G8F and her skin is definitely not that dark:
  • jcbunnjcbunn Posts: 271
    Llynara is using 3Delight textures (RSL) and has placed lights shining directly on and to the side of the figure.
    while you are using Iray textures (MDL) and only using the default scene lighting.
    both your and Llynara's look good
  • BeeMKayBeeMKay Posts: 7,019
    She's also coming across like the OP's render in these promos: https://www.daz3d.com/fantasy-poses-for-anneka-she-devil-and-michael-7
    Actually I'm using Iray textures with Sveva Sci Fantasy Lights for Iray and a low bloom on. I'm wondering if the OP loaded the default textures, which I believe are 3 delight.
    edited September 2017
    Thank you Llynara for the lighting information, for Anneka the default is Iray Uber, the 3DL textures are a bright red
    Post edited by jcbunn on
