New UV maps
Let's say I created new uv zones so I can texture a skin in Substance Painter. I import the new the UV and texture and select the new UV set instead, for example, Genesis 8 Female uv. Where I'm a little unsure is what if I wanted t make said texture/uv available for sale? Do I need to somehow convert my new UV zones/set back to the Genesis 8 zones. Or am I way off base and overthinking this?
  • BeeMKayBeeMKay Posts: 7,019
    No, you don't have to convert your UVs back, they would be custom UVs. But you'd break compatibility with tools that depend on the G8 UV-mapping, like https://www.daz3d.com/ultimate-make-up-for-genesis-8-female-s
  • It would depend on how much mapping you did - simply rearranging the UDIMs onto a single UV square by moving and scaling them wouldn't be allowed, snce it's essentially the default UV set, but a true remap would be distributable. Supplying a chnaged set of surfaces, however, might include too much of the geometry in the file.
