Errors Encountered with Greebles Cityscape Set [Fixed!]
dawnbladedawnblade Posts: 1,723
edited September 2017 in Technical Help (nuts n bolts)
I'm getting a bunch of errors loading the Cityscape set in Stonemason's Greeble City Blocks in the latest version of DS. This Cityscape loads all blocks into one scene, so you don't have to add each block and arrange them. Thank you for including this @Stonemason. Any chance you could include it in your other Greebles sets? smiley
First I get the "Unable to load Scene Items" dialog (my content directories are the default locations):
Here are just a couple of errors from the log file,  but there are similar errors for the other blocks. These files do exist in those locations:
Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/SMCGBlock1_1992/SMCGBlock1_1992/maps/uv.dsv
Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/SMCGBlock1_1992/SMCGBlock1_1992/geometry.dso
Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/SMCGBlock20_16280/SMCGBlock20_16280/uvs/default.dsv
Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/SMCGBlock20_16280/SMCGBlock20_16280/geometry.dso
Here is the set upon completion. Not sure if anything is missing from it:
Here is one with terrain, if it helps:
Any suggestions? Is anyone else getting these errors? It's not happening with other products.
Post edited by dawnblade on
  • NorthOf45NorthOf45 Posts: 5,692
    There's a new version out today, but some of the blocks (#4, #10, #15) don't load properly, just a big grey box. That usually means a mismatch between the geometry and material.
  • dawnbladedawnblade Posts: 1,723
    Thanks! I opened a ticket shortly after I created this thread, and tested today's update earlier today. Strange that those 3 blocks work fine in the other null groups they are in. It's only Null1 that is wonky.
    They did fix the error that was causing the "Unable to load Scene Items" dialog box to appear, so we're getting closer!
    I am happy to report that this issue has been resolved by Daz! They even updated the ReadMe page. Thank you Daz! smiley yes
    Great! Quick turnaround.
