Subdivision Weird Result
Please can anyone help me with SubD error. When I SubD to 2 or 3 I get this weird result on eyelids. I did everything but it won't go. Any tips??
  • Does that happen with the base, or only with certain morphs applied?
  • I applied HD Morphs from diffeernt characters and vascularity morphs.
  • Try removing morphs - or adding them - one by one and see if you can figure out the trigger.
  • ValandarValandar Posts: 1,418
    Also, which figure is this?
    Looks like G3M judging by the top of his parameters pane.
  • vwranglervwrangler Posts: 4,990
    edited September 2017
    I'm actually curious about the left side of the parameters pane. Why are there two of everything when there's only one figure selected? I have Gwenbleiz and Shape Shift (the blue sliders, the red are DAZ head and body morphs), and those morphs should be showing up only once per figure.
    Even if they'd been passed on to Whiskers, they wouldn't be showing as doubled morphs when Whiskers itself isn't selected. Something is off there.
    Post edited by vwrangler on
    Did previous male figures have morphs with the same names by chance? Could be a GenX issue from transferring characters.
    Post edited by Lissa_xyz on
  • Thanks everyone but I figured it out. Actually there were multiple HD morphs and Darius 7 HD morphs was creating the issue so I removed it and here is the result
    https://www.daz3d.com/gallery/#images/433161
