Issue - toonimal kitty rendering all white - resolved
Worlds_Edge
I decided to see how my toony figures render. Chip came out fine (didn't render fully, I was just testing), however toonimal kitty kept rendering white, instead of either the gray or orange/beige. Those colors/materials did appear in the viewport, but just would not render. I tried in iray and in 3delight, and I had the same issue. Does anyone know why I'm having this issue and how I can fix it?
Post edited by Worlds_Edge on
In 3DL check the Ambient...it should be 0 and black...not 1 (or 100) and white/any other color.
Ok, thank you both. After I finish rendering something else I will try both your suggestions :)
That's usually for a specific shader...the AoA SSS shader.
Restarting Daz Studio worked. It's weird that one figure would render with textures while the other wouldn't, but restart worked so I'm good with that. I'll try that first next time I have an issue :) Thank you!
