User Older PC Content in Iray
dawnydawny
in New Users
Hi everyone,
My latest question is, how do products like this: https://www.daz3d.com/fairytale-collection-fairytale-story, work in Iray?
I'm after some cost effective ways to get a bit of background variation in my renders. I find all the choice somewhat overwhelming I have to say, so suggestions are also welcome.
Thank you :-)
There's already a thread, try https://www.daz3d.com/forums/discussion/195711/what-is-the-best-way-to-convert-older-products-to-be-iray-compatible#latest
As for the conversion, the environment works pretty well straight out of the box.
Here's a render where I just loaded the environment:
And here's the same set, but I converted the surfaces of the environment to Iray, and adjusted the glossy roughness to .55.
As you can see, the difference for this particular item between 3DL and Iray shader is minimal.
Thank you, yes that does look pretty similar :-)
