Somehow key commands went away ... ??
Oso3D
in The Commons
Since yesterday, for some reason, none of my key commands work (for save/delete/anything). It only affects Daz and I've rebooted and so on.
Is there some obvious setting I missed?
there is a checkbox to turn off shortcuts
Any rough pointers on where I'd find that checkbox?
cant remember if under preferences or the F3 menu, or mebbe i'se brain farting >.<
can never remember how to turn off the orange highlighting.
or how to turn off the ground grid. in poser was ctrl+G, iirc
What's the F3 menu?
The one you see when you press the F3 key.
But that may not work for you either of course, in that case Window > Workspace > Customize
Strictly that's a dialogue, not a menu. The toggle is for the ketboard (WASD) navigation, I don't think there's a geernal toggle - however, you can reload just keyboard shortcuts via the Import... button in Customise.
Turned out I needed to import Actions. That was the key.
And yeah, if none of my key commands are working, saying 'pull up a menu by hitting F3' is... also not going to work. ;)
Yep, I managed to do that once. It took me forever to figure out how to get them restored, about two months. All of the directions I found started with that F3 key. I ended up giving up for a while and just living with the fact I had no shortcuts. That was a frustrating two months until I finally found the answer.
