Interiors The Model Agency
Does anyone know if I can use my own photos on the wall and portfolio. Or are we stuck using the images provided in the product.
Thanks,
Kent
Thanks,
Kent
The frames and cards are separate items, the frames should fairly easily take any photo (looking at the current textures applied you may want to add a bit of bleed at the edges), the cards would require placing an image (actually two, it think the one map does front and back) on a template but you should be able to use your own photos (or renders) for that without any great difficulty.
Yes, it's no problem to use your own images. There are 19 templates covering everything from the pc keyboard to the cards on the file cabinet, but the ones you'd be interested in are book cover, book page, calendar, (wall) frame, model card, print (photos), and tear sheet (magazine page).
