To bright / white!?
no-mensch
Hi all,
I have a noob-problem and I dont find a solution anywhere for that.
So sorry if the problem is known and solved.
I want to render a scene from outside. I have a envoirement, switched the cam to outside with view to the entrance.
The problem is, everything is to bright.
Inside the envoirement it looks very nice. But outside there is to much light.
How can I change that?
Screenshot below.
Thank you so much for helping me!
Best,
Norman
You need to change the Tone Mapping settings to match daylight. I can't tell you what setting to use, but Exposure Value has an overall effect on the entire scene. The default value (13.00) is more or less daylight, and it's probable that for your interior scene, the values were lower.
It's one of these things you have to play with to get it right, but it's way easier than changing all the lights.
Hi all,
Screenshot below.
Best,
Norman
Your screenshot isn't showing
Sorry,
This is a doubblepost. My bad...
Original Post with screenshot here:
https://www.daz3d.com/forums/discussion/194531/to-bright-white#latest
Thank you
I've merged the two threads.
