3delight
rmckeownrmckeown Posts: 0
Quality 4 renders crash Daz 4.5 on my machine (i7 12gig vista home premium 64 bit)
It seems the problem is the 3 delight software.
Do I need to install that separately, and from where?
Thanks
  • wancowwancow Posts: 2,708
    wow, lots of 3Delight crashes today... durn... not good!
  • Pixel8tedPixel8ted Posts: 613
    edited March 2013
    Thanks
    That actually makes me feel better. I have an older machine that render crashes a lot as I prefer to render using Quality 4. Currently, I treat every scene like it's going to crash and save it out before doing a render so I don't have to start from scratch. Changing a light setup or the render size will usually let my machine complete a render. It's a solution but not a great one.
    Post edited by Pixel8ted on
  • Richard HaseltineRichard Haseltine Posts: 109,240
    You are using the 64 bit version? Do you get a crash report? If you use WIndows Task Manager how much RAM is DS using when it crashes? Do you have progressive rendering turned on in your Advanced render Settings - if so, turn it off as it uses an excessive amount of memory (it's really only useful for previews that you are going to stop early on, checking lighting levels say).
  • rmckeownrmckeown Posts: 0
    OK, did a few tests...
    Reset machine, loaded a basic character and rendered at quality 4 size 5000 pixels x 5000 pixels.
    Then tried to render the scene achieved at the end of the tutorial fiery genesis.
    Setting 100pixels x 100 pixels, CPU was on average at 35%, ram at 30% rendered ok in 4 minutes
    Finally, tried to render the same scene at 250 x 250 pixels.
    After 3 minutes it have reached over 95%, the cpu usage had dropped to 35% (at times it had been 100%)
    Ram 30%
    At this point it crashed and asked me to submit a bug report, which is attached. (rename to .zip)
    Help please!
    That sounds like the behaviour if Progressive render is on - did you check that?
    I uninstalled and loaded the new version available today - Rendering now as sweet as a nut - Yeah
    By the way, rendering with 3delight is now standard with quality 3 AND 4
    thanks for the help folks
    boy am I glad to hear that! I just completed a render I was absolutely sure would take 8+ hours... 3DL stand alone did it in less than four... I was worried I was gonna start experiencing crashes the way everyone else was...
