Which graphic card would be the best for DAZ Studio 4.9 IRay
AD
Hi together,
I want to buy an used PC with 2 graphic cards NVidia GTX Titan à 6 GB. Could perhaps somebody tell me, if this works very good with DAZ Studio 4.9 IRay Rendering? The last days I found here in the forum a thread with many different cards for using IRAY Rendering, but - sorry - I don't found this thread again.
The Iray performance on that old card will be around the same as a current GTX 1060 6GB.
The issue with that is that the GTX Titan uses almost double the power of a GTX 1060.
Thx for your information. Perhaps you could tell me, which NVidia Graphic card would be better for IRay?
That would all depend on your budget.
Here is a list of cards in order of performance
Hello JamesJAB,
thank you very much - yes I was looking for this listing of graphic card. Thx for your help!
I think, I shall buy an PC from Mindfactory and I would take 2 of these cards here 11GB ZOTAC GeForce GTX 1080 Ti AMP Aktiv PCIe 3.0 x16 (Retail)
and hope it will work with IRay.
Yes those will work very nice with Iray.
Keep in mind with Iray, you may still drop to a CPU only render when working with large complex scenes that have multiple characters in them.
The trick with Iray is thet the entire scene needs to fit into the VRAM for each GPU that participates in the render job. (Your GPUs do NOT combine VRAM)
Do you know, if there is an updated list somewhere with newer graphic cards?
Add:
a bunch of RTX Quadros almost no one has seen at prices that are truly scary.
RTX Titan 24Gb $2500
RTX 2080ti 11Gb around $1200 depending on model
RTX 2080 8Gb around $800
RTX 2070 8Gb around $500
RTX 2060 6Gb around $350
GTX 1660ti 6Gb around $280
GTX 1070ti 8Gb around $450 (this card is not in production and stocks are low)
