From Photo(s) to 3D
Analog-X64
There is now a way to take multiple pictures of an object and turn it into 3D. This was from a tutorial. I was able to export the file as OBJ and bring it into Bryce. Its a quick and dirty render using one of my previously setup scenes as a backdrop.
I'm sure the pro's here could do amazing things with it.
The tutorial contains 40 pictures of this statue, the images are sent up to a server (cloud service) and then an e-mail is sent to you when the model is ready to download in a native format, at which point you can export to .dwg, .obj and a few others I didn't recognize.
The original concept is to turn objects into 3D so you can print the object with a 3D printer, as soon as I found out about this... first thing that came to mind was Bryce :)
What's the link?
How is the quality?
I didnt post a link, cause I'm not sure if it would violate any rules. But is an Autodesk product called 123D Catch
You can pick high quality meshes, I just picked the default lo-res one just to test. I'm going to try making one of my own from scratch.
That is interesting
