Best way to clear or reset the timeline
dash2128
What is the quickest way to reset the timeline, to start creating a fresh animation?
I have a walking figure that I wish to completely reanimate, perhaps several times.
Before resetting the Total and FPS, do I just delete the keypoints?
Or is there a way to clear the timeline with...say...a single click?
Post edited by dash2128 on
Select All, then Edit>Object>Clear Animation sub-menu.
Thanks!
I had some success using your directions, however I never located 'Animation sub-menu'.
When I reach '>object', it takes me to (3 options) >clear selected items, 'clear selected pose' and 'clear selected shape'.
(I'm using 4.9, so I'm curious about the 'sub-menu' option.)
But that's already helped, some!
It should have the Clear Animation sub-menu (flyout menu) unde the Zero sub-menu.
Hmm....
I still don't see 'sub-menu'.
I'm working on Windows 7.
If I can zero out Timeline for another attempt, but save the character and background/scene (without having to start over) I can keep working on a scene until I get it right, and make progress again.
I attached what comes up on my screen, maybe you can tell if I'm searching the right menu.
Your screenshots show sub-menus - a sub-menu is a menu that appears when you hover over an entry in the main menu, listing several commands.
(If I can add a chuckle- my fault) Yes, I know what a sub-menu is. I totaly misread your post, when I read: >Animation sub-menu', instead of 'Animation'.
Sorry, that mistake totaly confused me.
I did partially succeed in clearing the scene, but not (yet) by following your direction. I will get on it.
Thank you, again, for your assistance!
There is a really simple trick you can do in Daz Studio.
BANG! all keyframes gone. Repose character ( s ) if needed by going to:
Edit > Figure > Zero > Zero Figure Pose
And you good to go again!
Good luck!
Hey, thanks!
I was still having problems with that issue.
