Celebrity Look-a-Likes for 3D figures Part 2
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
I have been eying her, love the elf aspect. But I can see where if she was tweaked, and again, the right hair she could be a close Sansa..I wish the artist who did Natalie Dormer would create a Sansa and Dani..
I found a Cersi.. https://www.renderosity.com/mod/bcs/vyk-sersee-for-v4/98618 I think she's just for Poser though.
There's also this one that is V4 as well, but you can use them in Daz if you get a skin converter to Iray. https://www.renderosity.com/mod/bcs/sav-electra/90575/
But it's funny you mentioned Cersi because the guy who did the Natalie Dormer you talked about has just put up a WIP of that character in his Gallery over on Rendo. He goes by Sangriart over there if you want to check it out. But if he's going through the GOT women you may just get your wish after all.
Oh yes, I can see her as Cersi, especially the first pic. Love the gallery image he (she?) worked up! I do hope he decides to go thru all the GOT ladies..
I didn't know there was such a thing as a skin converter. I have Human essentials for Iray and anagenessis, would those be what you meant, or it's a seperate thing?
There are a few about. There's this one here: https://www.daz3d.com/iray-converter-for-generation-4 and there is one called Convert It! V4 skins over on Rendo. I think you should be able to use Human Essentials though I'm not 100% sure there but I do know you can use Anagenessis 2 for non Genesis figures because Dimension-Z added a freebie script for doing that at the start of the thread about the product here: https://www.daz3d.com/forums/discussion/110976/n-g-s-anagenessis-ii-revolution-commercial/p1
I hope that makes some sense to you and it's always useful to have a trawl around the forums looking for posts that ask about converting V4 or M4 skins to Iray just for recommendations and tips. I've learned so much myself just doing that. I've found that this isn't just a friendly and pleasant forum but it's also an amazing resource in itself!
Thanks for all the info,will check it all out. I probably shouldn't clog up this thread but looks like we have options for GOT gals and more coming!
Electra by SAV ( a brilliant woman named Joanna, sadly no longer living) is the same actress as Cersei in her role as the queen of Sparta in 300 (so many years ago), so you would only need to change the hair and costume.
I have the Daenerys that she did, as well as the hair and the dress.
Obviously the one by Vyktohria is so dead on there is no question.
Which one? The only one I see is this older one.
https://www.renderosity.com/mod/bcs/index.php?ViewProduct=95233&AID=666
Electra is really close, with the right hair and clothes she'd be gorgeous. Sad to hear she is no longer with us. Such talent! I've been eying her Dani, but I prefer working with the newer model gals cause I'm a noob.
Free Poser archaelogist face by me from a famous adventure movie. For the texture I use SAV Boris Di Conti from Renderosity, but if you can find a better one, do it. For hair I use CQ Event Hairstyle from DAZ unless he's wearing his hat, then I use Boris Di Conti non-bald texture. You need Morphs + + and basic morphs for Michael 4. Set the body at bodybuilder 0.600. Folder goes in your Faces folder. It's for the Dr. Graverobber costume at Renderosity by Cybertenko.
https://www.dropbox.com/s/lny75yko39e2hum/Ford face.zip?dl=0
Here's a sample render with Gconrad's face pose with a few personal tweaks (like Ford's broken nise that slightly angles to his right).
Sincerely,
Bill
I love it! Looks like you found a great texture. Personal tweaks are always good. I don't know how I missed the nose. I will work on it.
https://www.daz3d.com/lyra-hd-for-genesis-8-female can look like Elle Fanning, from the right angle. I noticed the resemblance in an image (at Rendo galleries) posted by someone named daznewb.
More like her sister, Dakota Fanning.
Don't really see it myself but like the render though.
yes, that was what I see and think, too
WIP for a Ridley morph I'm working on, mix of a zbrush sculpt and dialspinning. Still needs more tweaking though ::shrug::
That's fantastic.
Awesome thread this is! I been trying to find a David Hasselhoff model for years now. Is there one?
This same artist has made a new character called "Lionella" for G8F that is based on Lena Headey who plays Cersei Lannister on Game of Thrones. It is another spot on likeness:
https://www.renderosity.com/mod/bcs/lionella-for-g8f/122560/
I'll be looking out for this one. Now if only I could get that 3 bun hairdo.
This is the closes I've seen: https://www.daz3d.com/naughty-mohawk-for-genesis-3-females
Yes, I agree, definitely more like Dakota than Elle. As soon as I saw Lyra's first promo image I thought of her. It's not noticeable in all renders but it's there for sure in others, even if it wasn't intentional.
An Excellent Cersei Lannister/ Lena Headey, has just been released over at renderosity.
Thats really close
- I saw the picture first and thought 'Rey' before I read the words and saw it is indeed supposed to be Daisy Ridley. What texture/hair are you using there?
The hair is Devil May hair for the main part (just the base), with the wispy front strands from GeeGee hair (used the geometry editor, removed the rest of the polygons apart from 'BangFinerL' and 'BangFinerR'. Both have Iray 03 material from the base set and PhilW's Hair Lustre Shaders applied (Brown @80%).
The skin is a custom but since it was originally only intended for personal use it uses some non-MR resources, I'll have a look into whether any of the MRs I have on hand are usable for freebies on G8 or not and see if I can put an alternative together from those. Otherwise I'll go through my library and see if anything else works for it.
Morph will probably be up as a freebie once I work out the last bit of stuff with her jaw and mouth (it does need Rarestone's morph pack and the Gen8F Head Morphs though, my sculpting skills weren't up to more than a rough starting point)
Lena Heady morph for Genesis 8. This should satyisfy those who want mirror-like look-alikes.
https://www.renderosity.com/mod/bcs/index.php?ViewProduct=122560&AID=666
https://www.renderosity.com/mod/bcs/index.php?ViewProduct=122509&AID=666
I am not seeing the prince that was promised, Kit Harington. I am seeing the wunderkind, Wil Wheaton.
