Questions with Measure Metrics(solved)
timnaastimnaas Posts: 121
edited August 2017 in The Commons
Is there any plans on updating this for G8F, or will the G3F rig work on her ok! I remember that the G2F version didn't do too well on G3F.
Also, how does one use the cup size setting (32a, 34b, 36dd, etc.) so that I get the correct cup size. I see it in the parameters tab, but when I try to change it  (a, b, c etc) nothing is happing, am I missing something
Post edited by timnaas on
  • Check your DIM list - I thought Figure Metrics (which is the figure-specific bit) had been updated.
  • timnaastimnaas Posts: 121
    Well, I ususally do a manual d/l. I haven't used dim for quite a while. I when to my Product library and d/l the 4.9XX version and installed it with the installer, but nothing showed up for Genesis8??
    I'll take a look at dim
  • Figure Metrics is a separate download from the plug-in
    edited August 2017
    Ok, I just tried using the dim to stall it, but still no go. It update Genesis1-3, but I'm not getting the Genesis8 files. I looked at both locations(my "C" drive and my "f" drive which is my primary one). Seems like I'm missing or it's not installing the genesis8 files. Or it not giving me the Updated MeasureMetrics for some odd reason!
    Is there anywhy to open up the "exe" file to see what is int it. 7zip won't do it unless I'm doing it wrong.
    Or is there a why I can just get the zipped file and just manually do it that why
    I never really liked or trusted those "installers" anyways.
    1920 x 1080 - 269K
    1920 x 1080 - 289K
    1920 x 1080 - 289K
    1920 x 1080 - 276K
    1920 x 1080 - 277K
    1920 x 1080 - 241K
    1920 x 1080 - 250K
    1920 x 1080 - 237K
    Alright......never mind. Figured out what I did wrong. Overlooked one of the files that needed to be installed..........DUH-OH!!!surprise
