Viewport showing black background
How do I set the viewport so I see the light blue background as opposed to a dark black one?
If I muck around in render settings, sometimes it pops back to the light blue, which I find much easier to work with - but haven't figured out specific setting/command. Putting to Open Gl worked one time, but not now.
Theer are two "background colours". There's the Viewport Background Colour, set in Window>Style>Customise Style, which doesn't render but is persistent between sessions. There's the backdrop, set in the Environment pane, which by default does render but which isn't persistent between sessions (but is saved in the Scene file and read if the Scene is Opened, by default).
Thanks - that fixed it.
